[postgis-devel] bug, st_within not working for polygon,polygon
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Wed Jul 16 08:36:44 PDT 2008
Ingo Klinkmann wrote:
> Hi,
> The st_within and st_contains functions does not work as excpected when working with polygons
> on postgis1.3, geos 3.0.
> Steps to reproduce the Problem:
> -- Create Testtable and fill with Polygons of different sizes:
> CREATE TABLE geomtest (id serial,geom geometry) with oids;
> INSERT INTO geomtest(geom) VALUES (buffer(geometryfromtext('Point(5.0 46.0)',4326),0.7,20000) );
> INSERT INTO geomtest(geom) VALUES (buffer(geometryfromtext('Point(5.0 46.0)',4326),0.5,10000) );
> INSERT INTO geomtest(geom) VALUES (buffer(geometryfromtext('Point(5.0 46.0)',4326),0.3,1000) );
> INSERT INTO geomtest(geom) VALUES (buffer(geometryfromtext('Point(5.0 46.0)',4326),0.2,100) );
> -- The polygon is within the polygons we created above
> SELECT id  From geomtest WHERE st_within(geometryfromtext('POLYGON((5.0 46.0, 5.01 46.0, 5.01 46.01, 5.0 46.01, 5.0 46.0   ))',4326),geom);
> -- RETURN 0 rows.. which is IMHO a bug..
> -- This should be same query as above (DE9-IM-Matrix from ogc-doku)
> SELECT id  From geomtest WHERE st_relate(geometryfromtext('POLYGON((5.0 46.0, 5.01 46.0, 5.01 46.01, 5.0 46.01, 5.0 46.0   ))',4326),geom,'T*F**F***' );
> -- The revers-operation returns also 0 rows.
> SELECT id  From geomtest WHERE st_contains(geom,geometryfromtext('POLYGON((5.0 46.0, 5.01 46.0, 5.01 46.01, 5.0 46.01, 5.0 46.0   ))',4326));
> -- Tested on:
> -- Postgresql "8.3.3" POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STAT
> -- Postgresql "8.3.3" POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec 2007" USE_STATS
> -- Problem does NOT occur on:
> -- Postgresql "8.1.11" POSTGIS="1.1.6" GEOS="2.2.3-CAPI-1.1.1" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STAT
> -- (functions without st_ on postgis 1.1.x of course)
> greetings
> Ingo Klinkmann
Hi Ingo,
There are several fixes related to the containment tests in GEOS SVN -
can you try using the latest SVN of GEOS 3 to see if that resolves the
issue?
Paul, Mateusz etc. is it worth trying to nudge various people to get a
GEOS 3.0.1 release out? It seems this bug is being reported a lot...
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
