[postgis-devel] ST_Area, ST_Area2D
Obe, Regina robe.dnd at cityofboston.gov
Fri Jul 18 05:36:38 PDT 2008
Can I scrap ST_Area2D from docs and just replace with ST_Area? or is
ST_Area2D really the preferred name?  They both map to
LWGEOM_area_polygon, but
the docs list the ST_Area2D one which seems a bit more verbose and
unconventional.
Both IBM and ESRI on quick search just call it ST_Area
IBM -
publib.boulder.ibm.com/infocenter/db2luw/v9/topic/com.ibm.db2.udb.spatia
l.doc/rsbp4034.html
and Esri webhelp.esri.com/arcgisserver/9.3/java/geodatabases/st_area.htm
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
