[postgis-devel] Non-Join Join
Martin Davis mbdavis at refractions.net
Fri Jul 18 14:29:20 PDT 2008
I bow to the master.
Obe, Regina wrote:
> Wrong Martin.  Find all that are within 1000 with a left join using an
> indexed search and then throw out those that don't have matches.
> If it has no neighbor within 1000 feet then all its neighbors must be
> more than 1000 feet away.
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
> Martin Davis
> Sent: Friday, July 18, 2008 5:21 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] Non-Join Join
> Since you're trying to find all As which are *further* than a given
> distance from Bs, I don't think there is any "efficient" way.
> I think you pretty much have to do a self-join with a where condition
> like "where distance(geomA, geomB) > 1000".  Oh, and I guess you'll need
> a filter condition to compare only As and Bs.
> Paul Ramsey wrote:
>> Brain freeze:
>> Give a table
>> gid integer
>> geom geometry
>> letter varchar
>> where letter is a single letter,
>> how to efficiently find all the instances of the letter 'A' that are
>> more than 1000m from any letter 'B'.
>> P.
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
