[postgis-devel] lwpostgis.sql.inc.c?
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Mon Jul 21 09:52:53 PDT 2008
Obe, Regina wrote:
> Why does the trunk lwgeom/lwpostgis.sql.in.c  not called
> lwpostgis.sql.in
> Its screwing up the color coding on my editor.  In the branch versions
> it was named lwpostgis.sql.in
> I see we did split things out into sqlmm.sql.in etc, but that doesn't
> seem to explain this choice of naming.
> Thanks,
> Regina
Hi Regina,
The reason for this is that the PostgreSQL PGXS build system takes an
input file called <foo>.sql.in, runs it through sed to substitute the
path to the actual module, and stores the result as <foo>.sql. This file
is then copied to the correct contrib/ directory as part of "make install".
In order to allow PostGIS to generate the correct SQL for multiple
versions of PostgreSQL, we also need to run the output file through the
C preprocessor beforehand. So the overall process now looks like this:
i) lwpostgis.sql.in.c is run through the C pre-processor CPP to produce
lwpostgis.sql.in
ii) lwpostgis.sql.in is run through sed by the PostgreSQL PGXS build
system to produce the final lwpostgis.sql
Note that I used .c to make it obvious that the file is run through CPP
(plus it uses various macro subsitutions with respect to function types
such as IMMUTABLE, VOLATILE etc.) rather than being pure SQL. I can't
say that I've ever run in syntax highlighting problems, but I suspect
even an SQL syntax highlighter would fail due to the macros involved.
HTH,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
