[postgis-devel] Issue 31 in postgis: Negative distance buffer
codesite-noreply at google.com codesite-noreply at google.com
Tue Jul 22 02:52:09 PDT 2008
Issue 31: Negative distance buffer
http://code.google.com/p/postgis/issues/detail?id=31
Comment #6 by mark.cav... at siriusit.co.uk:
Thanks for providing the test results above. It does seem as if this is
a GEOS/JTS
issue, and I'm afraid the internals of GEOS are outside of my personal
sphere of
knowledge. It may be useful to file the same bug on the GEOS bugtracker
so that it
gets picked up there; unfortunately I'm not really sure how active the GEOS
developers are at the moment - perhaps someone else would be able to comment.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
