[postgis-devel] flex problems on RHEL 5.1
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Mon Jul 28 02:22:38 PDT 2008
Jorgen Austvik - Sun Norway wrote:
> The man page says:
> ------------8<------------------8<------------------8<------------------8<------
> <snip>
>        -ooutput
>               directs flex to write the scanner to the file output
> instead of lex.yy.c.  If you combine -o
>               with  the -t option, then the scanner is written to stdout
> but its #line directives (see the
>               -L option above) refer to the file output.
> <snip>
> Version 2.5                       April 1995 FLEX(1)
Right, so it seems that the preceding whitespace shouldn't be specified.
Obviously I missed this when working on the new build system (I added it
for readability), so I've just committed back the original version to
SVN without the whitespace.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
