[postgis-devel] Documenting Aliases
Kevin Neufeld kneufeld at refractions.net
Mon Jul 28 10:49:17 PDT 2008
I don't think there is, but I'm not sure.  My understanding is that TOC
is automatically generated by picking out the refname in the refnamediv
tag in a refentry.  You can provide multiple refnames, but only the
first one is picked out for use in the TOC.
Since we want to see these functions listed in the TOC, I don't see any
other way than to treat them as the others with a See Also section.
Cheers,
Kevin
Obe, Regina wrote:
> We have a couple of aliases for functions such as
> ST_WKTToSQL
> ST_WKBToSQL
> Is there an easy way to give things like ST_GeomFromText 2 references.
> It seems kind of silly to have to document both variants on separate
> pages although both should probably be listed in the TOC. I'm not sure
> if one name is preferred over another (though I would guess
> ST_GeomFromText would be the preferred).
> Thanks,
> Regina
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
