[postgis-devel] Issue 44 in postgis: ST_Relate(geom, geom, pattern) is case sensitive
codesite-noreply at google.com codesite-noreply at google.com
Tue Jul 29 17:22:41 PDT 2008
Issue 44: ST_Relate(geom,geom,pattern) is case sensitive
http://code.google.com/p/postgis/issues/detail?id=44
New issue report by pwramsey3:
What steps will reproduce the problem?
1. Run any st_relate op using a patter with lower-case strings
What is the expected output? What do you see instead?
- answer should be case insensitive
Issue attributes:
	Status: Accepted
	Owner: pwramsey3
	Labels: Type-Defect Priority-Medium
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
