[postgis-devel] Re: [postgis-users] create tables smarter
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Thu Jun 5 05:53:46 PDT 2008
Markus Schaber wrote:
>> I don't see this as being particularly difficult to implement... If
>> there's agreement on this approach then I'd be happy to write the C code
>> necessary. Is there a preference on the structure of the typmod values,
>> or is Frank's suggestion of:
>> GEOMETRY(<dimension>,<srid>,<type>)
>> acceptable?
> I think this is acceptable, feel free to go ahead and present
> patches. :-)
Hi Markus,
Welcome back from holiday! ;)
I must admit that I find GEOMETRY(<dimension>,<srid>,<type>) fairly
unintuitive; I'd prefer GEOMETRY(<type>,<dimension>,<srid>) as an
alternative. Also, when we determine the maximum size of the SRID field,
we can easily add a CHECK constraint on the table to return an ERROR if
someone tries to go above the limit.
Given the massive re-working of the codebase (see
http://postgis.refractions.net/pipermail/postgis-devel/2008-May/003010.html
and
http://postgis.refractions.net/pipermail/postgis-users/2008-May/019886.html
for a catch-up) I'm happy to work on this in SVN trunk when we decide on
the final layout. The hardest bit will be trying to keep the maintenance
of both the new code for 8.3+ and the existing code relatively sane.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
