[postgis-devel] Re: [postgis-users] create tables smarter
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Thu Jun 5 08:12:50 PDT 2008
Markus Schaber wrote:
> But when you do operations like string concatentation, or intersections
> etc, the result type may require different typemods.
Hi Markus,
I don't think that would be a problem; think about the case where you
have this:
SELECT 'name1'::varchar || ' ' || 'name2'::varchar;
I could expect both name1 and name2 to come from a varchar(5) column,
and whilst the above calculation will work fine and return a new result,
I would not expect to be able to fit that result back into a varchar(5)
column.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
