[postgis-devel] Re: [postgis-users] create tables smarter
Stephen Frost sfrost at snowman.net
Thu Jun 5 16:15:33 PDT 2008
* Kevin Neufeld (kneufeld at refractions.net) wrote:
> What about geometric views?  I recall that in order to get mapserver to
> work with views, you had to trick it and manually put an entry into the
> geometry columns table.
> I suppose if we change geometry_columns into a view that looks at the
> system tables, it could also include the necessary information regarding
> defined geometric views.
Yes, view definitions also go into the same tables and can contain their
own typmod definitions, etc.
	Thanks,
		Stephen
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080605/fa140748/attachment.sig>
