[postgis-devel] Re: [postgis-users] create tables smarter
Paul Ramsey
pramsey at cleverelephant.ca
Thu Jun 5 22:58:53 PDT 2008
Well, as Regina noted, having views in GEOMETRY_COLUMNS is required to
make them visible in some applications.
On Thu, Jun 5, 2008 at 8:27 AM, Tom Lane <tgl at sss.pgh.pa.us> wrote:
> "Paul Ramsey" <pramsey at cleverelephant.ca> writes:
>> I'd propose the utility process by basically a side effect of ANALYZE
>> and clean up everything about GEOMETRY_COLUMNS. Remove dead entries,
>> find new ones, etc, rather than just restricting itself to the one
>> table it was (potentially) called on.
> No, you don't want to go there. If you try to implement it like that,
> then you'll get "tuple updated concurrently" failures because concurrent
> ANALYZEs on different tables will try to clean up the same rows.
> If you go with the typmod implementation, might it be possible to
> turn GEOMETRY_COLUMNS into a read-only view on the system catalogs?
> Then it wouldn't need any clean-up. It's not clear to me whether
> GEOMETRY_COLUMNS is supposed to carry any information that wouldn't
> be available from the typmod tags.
> regards, tom lane
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
