[postgis-devel] about lwcurve in postgis
xie jiong
xie_jiong at 163.com
Thu Jun 19 05:51:22 PDT 2008
SQL-MM specification's curve is the base class of circluar string and line string,
so use curve as circle isn't very proper i think.
----- Original Message -----
To: "PostGIS Development Discussion" <postgis-devel at postgis.refractions.net>
Sent: Thursday, June 19, 2008 7:40 AM
Subject: Re: [postgis-devel] about lwcurve in postgis
> 2008/6/18 xie jiong <xie_jiong at 163.com>:
>> HI:
>> in current postgis, lwcurve only represent circularstring, so why use
>> curve name?
>> Jiong
>> postgis-devel mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> One answer is that a circle is a curve.
> The correct answer is that the curved geometry support was developed
> to the SQL-MM specification, which supports only the circular string
> version of curves, so our naming convension is directly derived from
> theirs.
> Mark Leslie
> Geospatial Software Architect
> LISAsoft
> http://www.lisasoft.com/LISAsoft/SupportedProducts.html
