[postgis-devel] 1.3.3
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Fri Mar 28 13:46:18 PDT 2008
On Fri, 2008-03-28 at 12:35 -0700, Paul Ramsey wrote:
> Mark,
> Rather than revert the PreparedGeometry changes, I've placed them
> behind appropriate version checking so that they aren't available for
> GEOS < 3.1. Ditto for the topologyPreservingSimplify that was breaking
> GEOS < 3.0.
Okay. I'm not 100% convinced by the additional 3rd parameter here:
http://postgis.refractions.net/pipermail/postgis-commits/2008-January/000209.html.
I'd like to see evidence that avoiding the memcmp() will actually result
in a more than negligible performance boost, since it seems quite a hack
on the API :( It would make sense to do this before we release the next
version and people start using the new API in earnest.
> I have now tested and gotten things working for GEOS 2.2 versus
> PostGIS 1.3.3SVN. Only thing not working is the ogc regress test,
> that uses Covers/CoveredBy, which are only exposed in GEOS >= 3.0.0.
> So the next trick is to make the regression tests also
> version-sensitive.
Okay that's great.
> Anyways, I think we could cut a "safe" 1.3.3 release now.
I'd still like to resolve a couple more issues: if things work for GEOS
2.2.x we can close GBT #8. I also think it would be good to resolve GBT #6
and GBT #7 before we hit the release.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
