[postgis-devel] 1.3.3
Paul Ramsey pramsey at cleverelephant.ca
Mon Mar 31 09:38:09 PDT 2008
I have a regression failure on 8.3+2.2.3, in the ogc_regress set, but
that was because test Covers tests were added to that file, and Covers
isn't available in the 2.2.X series. Are you seeing something
different?  I (bad puppy) just decided to "see no evil" and not bother
farting with the regression tests to try and break it out.
P.
On Mon, Mar 31, 2008 at 4:27 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> On Friday 28 March 2008 20:49:33 Paul Ramsey wrote:
> > I've closed GBT#8.
>  On reflection, there is still something wrong with GEOS 2.2.3 on my
>  workstation here. While SVN head now compiles under 7.4, regression tests are
>  failing on most PostgreSQL versions I am testing here since some of the ST_
>  GEOS predicates are no longer appearing in lwpostgis.sql. Could you take a
>  look at this?
>  Many thanks,
>  Mark.
>  Mark Cave-Ayland
>  Sirius Corporation - The Open Source Experts
>  http://www.siriusit.co.uk
>  T: +44 870 608 0063
