[postgis-devel] Issue 66 in postgis: ST_Dump kills backend when fed CIRCULAR STRING
codesite-noreply at google.com codesite-noreply at google.com
Tue Nov 4 05:27:57 PST 2008
Issue 66: ST_Dump kills backend when fed CIRCULAR STRING
http://code.google.com/p/postgis/issues/detail?id=66
New issue report by robe.... at cityofboston.gov:
What steps will reproduce the problem?
1.  SELECT ST_Dump(ST_GeomFromEWKT('CIRCULARSTRING(220268 150415 1,220227
150505 2,220227 150406 3)'));
2. Crash
3. Does the same on both 1.3.4SVN and 1.3.3
Issue attributes:
	Status: Accepted
	Owner: robe.... at cityofboston.gov
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
