[postgis-devel] Issue 65 in postgis: ST_AsGML kills the backend when fed a CIRCULAR STRING
codesite-noreply at google.com codesite-noreply at google.com
Tue Nov 4 06:05:03 PST 2008
Issue 65: ST_AsGML kills the backend when fed a CIRCULAR STRING
http://code.google.com/p/postgis/issues/detail?id=65
Comment #1 by mark.cav... at siriusit.co.uk:
Okay - I've applied a fix for this to 1.3 SVN and trunk. It looks like the
ST_AsGML()
function was trying to inspect geometries by default, rather than throwing
an error
on unknown types like the other ST_As*() functions. Since there is no
support for
types other than the basic OGC types, I've made ST_AsGML() do the same.
ATB,
Mark.
Issue attribute updates:
	Status: Fixed
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
