[postgis-devel] Issue 68 in postgis: ST_Shift_Longitude doesn't work with MULTIPOINT
codesite-noreply at google.com codesite-noreply at google.com
Wed Nov 5 03:10:48 PST 2008
Issue 68: ST_Shift_Longitude doesn't work with MULTIPOINT
http://code.google.com/p/postgis/issues/detail?id=68
Comment #1 by mark.cav... at siriusit.co.uk:
Should now be fixed in 1.3 branch/trunk. Note I've taken the line of
returning a
friendlier error message rather than looking at supporting CURVETYPE;
perhaps this
part is something to leave for 1.4?
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
