[postgis-devel] Issue 68 in postgis: ST_Shift_Longitude doesn't work with MULTIPOINT
codesite-noreply at google.com codesite-noreply at google.com
Wed Nov 5 04:40:01 PST 2008
Issue 68: ST_Shift_Longitude doesn't work with MULTIPOINT
http://code.google.com/p/postgis/issues/detail?id=68
Comment #2 by robe.... at cityofboston.gov:
Yah you can leave for 1.4.  I don't think its a commonly used function and
MULTIPOINT
is not a common geometry type anyway.  I just noticed the error when I was
coming up
with examples in the docs.  I had put in MULTIPOINT is not supported for
this one
(well for 1.4 docs).  I'll just amend to say fixed in 1.4
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
