[postgis-devel] Issue 65 in postgis: ST_AsGML kills the backend when fed a CIRCULAR STRING
Courtin Olivier
olivier.courtin at camptocamp.com
Wed Nov 5 04:50:33 PST 2008
On Nov 5, 2008, at 12:33 PM, Mark Cave-Ayland wrote:
Mark,
>> Well that fix, remove GeometryCollection support from ST_AsGML:
>> postgis_reg=# SELECT
>> ST_AsGML(geometryfromtext('GEOMETRYCOLLECTION(POINT(1 1))'));
>> ERROR: geometry_to_gml2: 'GeometryCollection' geometry type not
>> supported
> That was my fault as the GBT#65 fix was a little too strict - please
> can you test the fix I've just applied to SVN?
Yeap tested on 1.3 branches (r3256)
and that's fine for GeometryCollection support
(i.e same behaviour as in 1.3.4rc2)
Tks !
Olivier
