[postgis-devel] Issue 66 in postgis: ST_Dump kills backend when fed CIRCULAR STRING
codesite-noreply at google.com
Wed Nov 5 09:11:05 PST 2008
Issue 66: ST_Dump kills backend when fed CIRCULAR STRING
http://code.google.com/p/postgis/issues/detail?id=66
Comment #5 by robe.... at cityofboston.gov:
Mark,
What about the case in 64-bit where it returns 0 rows. It should return 1
row in
this example or throw an error that this type is not supported. I actually
haven't
looked at ST_Dump code at all, but would be willing to take a stab at it if
no one
else more experienced has time to do so.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
