[postgis-devel] Issue 69 in postgis: ST_Translate crashes when fed circular string
codesite-noreply at google.com codesite-noreply at google.com
Thu Nov 6 10:19:18 PST 2008
Issue 69: ST_Translate crashes when fed circular string
http://code.google.com/p/postgis/issues/detail?id=69
Comment #2 by robe.... at cityofboston.gov:
Mark,
I've been looking at this one too and I fear this one may be a tad bit more
complicated so maybe the best we can do is throw an error for 1.3.4 to
prevent the
function from crashing and revisit in 1.4.  There are a couple of areas
that may be
the culprit starting in the
lwgeom_affine_recursive in lwgeom_functions_basic.c
1) There is an assumption here that all geometries can be broken down to
LWPOINTS, LWLINES, LWPOLYS.  In the case of curve - I think we would need
to add
LWCURVE, LWCURVEPOLY to the mix.
2) The fact that it crashes and doesn't just return a null leads me to
believe one of
the lwgeom_*_inspected is doing something funky with CURVE types.
So I guess the good news is that if we fix these dependency functions, it
will
probably fix a whole class of non-GEOS PostGIS functions that don't
currently work
with CURVES.
To
Paul or the other Mark (Leslie),
I recall Paul saying Mark Leslie is working on curve support fixes.  Does
that include
fixing Affine or the aforementioned dependency functions?  Don't want to
step on
anyone's toes when I come across these things that don't work if they are
already
work in progress.
Anyrate maybe I'll test some more functions with curved geometries - and
come back to
this one and maybe get a better idea of the class of functions that don't
work with
curves to better find the smoking guns.
Thanks,
Regina
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
