[postgis-devel] Issue 66 in postgis: ST_Dump kills backend when fed CIRCULAR STRING
codesite-noreply at google.com codesite-noreply at google.com
Thu Nov 6 23:35:27 PST 2008
Issue 66: ST_Dump kills backend when fed CIRCULAR STRING
http://code.google.com/p/postgis/issues/detail?id=66
Comment #10 by robe.... at cityofboston.gov:
Okay just tested this and seems to work fine now.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
