[postgis-devel] Issue 70 in postgis: ST_NPoints Crashes with Curves
codesite-noreply at google.com codesite-noreply at google.com
Fri Nov 7 06:36:06 PST 2008
Issue 70: ST_NPoints Crashes with Curves
http://code.google.com/p/postgis/issues/detail?id=70
Comment #1 by mark.cav... at siriusit.co.uk:
Should now be fixed in 1.3 branch and HEAD. Please test :)
ATB,
Mark.
Issue attribute updates:
	Status: Fixed
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
