[postgis-devel] Issue 58 in postgis: bounding box of circular string is incorrect
codesite-noreply at google.com codesite-noreply at google.com
Fri Nov 7 07:56:49 PST 2008
Issue 58: bounding box of circular string is incorrect
http://code.google.com/p/postgis/issues/detail?id=58
Comment #2 by mark.cav... at siriusit.co.uk:
Mark,
Can this be marked as fixed?
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
