[postgis-devel] 8.4+1.3
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Tue Nov 11 13:47:17 PST 2008
On Tue, 2008-11-11 at 10:03 -0800, Paul Ramsey wrote:
> Mark,
> I looked over the patch in
> http://postgis.refractions.net/pipermail/postgis-commits/2008-August/000413.html
> and the *recheck value seems to never get used. So is the main thrust
> of the 8.4 compatibility just getting the opclass defns to work, by
> dropping the 'recheck' from the SQL?
> P.
Yeah. It is now the job of the index API to determine whether the index
scan is lossy, rather than hard-coding it inside the opclass.
Incidentally the sed fix I committed earlier should also strip off the
non-numeric part of "pg_config --version", so with this done "make
check" should work on PG 8.4.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
