[postgis-devel] AsGML & AsGeoJson patches
Paul Ramsey pramsey at cleverelephant.ca
Tue Nov 11 13:52:01 PST 2008
PSC folks,
I think we should add Olivier to the committers. Why? I'm too damned
lazy to merge in these patches :) (the 1.3 one failed and hand merging
the regression file is just beyond my will)
+1 paul
P.
On Wed, Nov 5, 2008 at 12:40 AM, Courtin Olivier
<olivier.courtin at camptocamp.com> wrote:
> Hi,
> I've made a patch related to export function, inside it:
> - AsGML
>  - Curve geometry nice error message
>  - GeometryCollection handle
>  - Code factorization between GML 2.1.2 and 3.1.1
>  - version parameter no more a a global one
>  - use decimal places rather than significants digits
>   (with doc update)
>  - trim trailing zero
>  - unit test file
> AsGeoJson
>  - add forgotten pfree on subgeometry size process
> - return geometry type name on error (i.e for curve)
> Gml3 output was widely test, Gml2 a bit less
> Patchs provided for 1.3 branches and trunk.
> Enjoy !
> FYI, Still on my Todo for theses export functions:
> - SVG Unit Test
> - KML decimal places
> - Trunk doc improve
> - RFC 5165 compliant (GML, GeoJson, KML also ?)
> - GML3 Curve handle (low priority)
> Olivier
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
