[postgis-devel] AsGML & AsGeoJson patches
Obe, Regina robe.dnd at cityofboston.gov
Tue Nov 11 14:09:58 PST 2008
+1
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Paul Ramsey
Sent: Tue 11/11/2008 4:52 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] AsGML & AsGeoJson patches
PSC folks,
I think we should add Olivier to the committers. Why? I'm too damned
lazy to merge in these patches :) (the 1.3 one failed and hand merging
the regression file is just beyond my will)
+1 paul
P.
On Wed, Nov 5, 2008 at 12:40 AM, Courtin Olivier
<olivier.courtin at camptocamp.com> wrote:
> Hi,
> I've made a patch related to export function, inside it:
> - AsGML
>  - Curve geometry nice error message
>  - GeometryCollection handle
>  - Code factorization between GML 2.1.2 and 3.1.1
>  - version parameter no more a a global one
>  - use decimal places rather than significants digits
>   (with doc update)
>  - trim trailing zero
>  - unit test file
> AsGeoJson
>  - add forgotten pfree on subgeometry size process
> - return geometry type name on error (i.e for curve)
> Gml3 output was widely test, Gml2 a bit less
> Patchs provided for 1.3 branches and trunk.
> Enjoy !
> FYI, Still on my Todo for theses export functions:
> - SVG Unit Test
> - KML decimal places
> - Trunk doc improve
> - RFC 5165 compliant (GML, GeoJson, KML also ?)
> - GML3 Curve handle (low priority)
> Olivier
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081111/36dcd5aa/attachment.html>
