[postgis-devel] AsGML & AsGeoJson patches
Paul Ramsey pramsey at cleverelephant.ca
Wed Nov 12 09:28:03 PST 2008
Kevin,
Could you put the wheels in motion to add Olivier to the committers?
Thanks!
p.
On Tue, Nov 11, 2008 at 10:46 PM, Kevin Neufeld
<kneufeld at refractions.net> wrote:
> +1
> Obe, Regina wrote:
>> +1
>> -----Original Message-----
>> From: postgis-devel-bounces at postgis.refractions.net on behalf of Paul
>> Ramsey
>> Sent: Tue 11/11/2008 4:52 PM
>> To: PostGIS Development Discussion
>> Subject: Re: [postgis-devel] AsGML & AsGeoJson patches
>> PSC folks,
>> I think we should add Olivier to the committers. Why? I'm too damned
>> lazy to merge in these patches :) (the 1.3 one failed and hand merging
>> the regression file is just beyond my will)
>> +1 paul
>> P.
>> On Wed, Nov 5, 2008 at 12:40 AM, Courtin Olivier
>> <olivier.courtin at camptocamp.com> wrote:
>> > Hi,
>> > I've made a patch related to export function, inside it:
>> > - AsGML
>> >  - Curve geometry nice error message
>> >  - GeometryCollection handle
>> >  - Code factorization between GML 2.1.2 and 3.1.1
>> >  - version parameter no more a a global one
>> >  - use decimal places rather than significants digits
>> >   (with doc update)
>> >  - trim trailing zero
>> >  - unit test file
>> > AsGeoJson
>> >  - add forgotten pfree on subgeometry size process
>> > - return geometry type name on error (i.e for curve)
>> > Gml3 output was widely test, Gml2 a bit less
>> > Patchs provided for 1.3 branches and trunk.
>> > Enjoy !
>> > FYI, Still on my Todo for theses export functions:
>> > - SVG Unit Test
>> > - KML decimal places
>> > - Trunk doc improve
>> > - RFC 5165 compliant (GML, GeoJson, KML also ?)
>> > - GML3 Curve handle (low priority)
>> > Olivier
>> > _______________________________________________
>> > postgis-devel mailing list
>> > postgis-devel at postgis.refractions.net
>> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
>> *The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure pursuant to
>> Massachusetts law. It is intended solely for the addressee. If you received
>> this in error, please contact the sender and delete the material from any
>> computer. *
>> * Help make the earth a greener place. If at all possible resist printing
>> this email and join us in saving paper. *
