[postgis-devel] AsGML & AsGeoJson patches
Kevin Neufeld
kneufeld at refractions.net
Wed Nov 12 10:30:53 PST 2008
Done. Welcome aboard Olivier!
-- Kevin
Paul Ramsey wrote:
> Kevin,
> Could you put the wheels in motion to add Olivier to the committers?
> Thanks!
> p.
> On Tue, Nov 11, 2008 at 10:46 PM, Kevin Neufeld
> <kneufeld at refractions.net> wrote:
>> +1
>> Obe, Regina wrote:
>>> +1
>>> -----Original Message-----
>>> From: postgis-devel-bounces at postgis.refractions.net on behalf of Paul
>>> Ramsey
>>> Sent: Tue 11/11/2008 4:52 PM
>>> To: PostGIS Development Discussion
>>> Subject: Re: [postgis-devel] AsGML & AsGeoJson patches
>>> PSC folks,
>>> I think we should add Olivier to the committers. Why? I'm too damned
>>> lazy to merge in these patches :) (the 1.3 one failed and hand merging
>>> the regression file is just beyond my will)
>>> +1 paul
>>> P.
>>> On Wed, Nov 5, 2008 at 12:40 AM, Courtin Olivier
>>> <olivier.courtin at camptocamp.com> wrote:
>>>> Hi,
>>>> I've made a patch related to export function, inside it:
>>>> - AsGML
>>>> - Curve geometry nice error message
>>>> - GeometryCollection handle
>>>> - Code factorization between GML 2.1.2 and 3.1.1
>>>> - version parameter no more a a global one
>>>> - use decimal places rather than significants digits
>>>> (with doc update)
>>>> - trim trailing zero
>>>> - unit test file
>>>> AsGeoJson
>>>> - add forgotten pfree on subgeometry size process
>>>> - return geometry type name on error (i.e for curve)
>>>> Gml3 output was widely test, Gml2 a bit less
>>>> Patchs provided for 1.3 branches and trunk.
>>>> Enjoy !
>>>> FYI, Still on my Todo for theses export functions:
>>>> - SVG Unit Test
>>>> - KML decimal places
>>>> - Trunk doc improve
>>>> - RFC 5165 compliant (GML, GeoJson, KML also ?)
>>>> - GML3 Curve handle (low priority)
>>>> Olivier
>>>> _______________________________________________
>>>> postgis-devel mailing list
>>>> postgis-devel at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>>> *The substance of this message, including any attachments, may be
>>> confidential, legally privileged and/or exempt from disclosure pursuant to
>>> Massachusetts law. It is intended solely for the addressee. If you received
>>> this in error, please contact the sender and delete the material from any
>>> computer. *
>>> * Help make the earth a greener place. If at all possible resist printing
>>> this email and join us in saving paper. *
