[postgis-devel] Issue 31 in postgis: Negative distance buffer
codesite-noreply at google.com codesite-noreply at google.com
Mon Nov 17 05:05:02 PST 2008
Issue 31: Negative distance buffer
http://code.google.com/p/postgis/issues/detail?id=31
Comment #8 by robe.... at cityofboston.gov:
Nicholas,
This is the bug report system.  I think you would have better luck and its
more
appropriate to ask your question to the postgis-users group which you can
subscribe
to from here
http://postgis.refractions.net/mailman/listinfo/postgis-users
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
