[postgis-devel] Issue 71 in postgis: Update section 4.2 of docs to describe manual adding to geometry columns
codesite-noreply at google.com codesite-noreply at google.com
Tue Nov 18 09:35:10 PST 2008
Issue 71: Update section 4.2 of docs to describe manual adding to geometry
columns
http://code.google.com/p/postgis/issues/detail?id=71
New issue report by robe.... at cityofboston.gov:
-----Original Message-----
Sent: Tuesday, November 18, 2008 12:37 PM
To: Obe, Regina
Cc: David Bitner
Subject: AddGeometryColumn() docs
Hi Regina-
    I am working on oge2ogr a bit .. and discovered with the new
1.6_trunk version, you can use a view as an ogr datasource. In order to
see the view, you can add a tables=view1 in the dsn, or just manually
add a geometry_columns entry for the view. This works great, I believe
it is then a first class citizen with an SRS.
    But apparently AddGeometryColumns() won't execute for a view. So we
were discussing an addition in section 4.2.2/4.2.3 of the manual to
talk a little bit about adding a geometry column entry manually..
    On the ogr2ogr side, I want to describe the technique in the pg
driver "man" page...
    I think this is a really important new feature of ogr.
    -Brian
Issue attributes:
	Status: Accepted
	Owner: robe.... at cityofboston.gov
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
