[postgis-devel] ST_Transform doesn't need Proj support?
Obe, Regina robe.dnd at cityofboston.gov
Thu Nov 20 07:19:36 PST 2008
I was looking at the lwpostgis.in.sql in 1.3 and I only  see a
#ifdef USE_PROJ  wrapped around the ST_AsKMLs.
Does that mean ST_Transform doesn't need projection support or am I
reading this wrong?
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
