[postgis-devel] ST_Transform doesn't need Proj support?
Obe, Regina robe.dnd at cityofboston.gov
Thu Nov 20 07:34:51 PST 2008
 The obvious reason why they would.  The 1.4 SVN ST_AsKML help ranks
number 1 on Google.
-----Original Message-----
Sent: Thursday, November 20, 2008 10:32 AM
To: 'PostGIS Development Discussion'
Subject: RE: [postgis-devel] ST_Transform doesn't need Proj support?
I thought that, but thought I would put it in anyway.  I suspect some
people may be looking at the 1.4 docs for 1.3 support since the
documentation on 1.4 is much better than 1.3.
Thanks,
Regina
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Thursday, November 20, 2008 10:26 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] ST_Transform doesn't need Proj support?
Obe, Regina wrote:
> I was looking at the lwpostgis.in.sql in 1.3 and I only  see a
> #ifdef USE_PROJ  wrapped around the ST_AsKMLs.
> Does that mean ST_Transform doesn't need projection support or am I
> reading this wrong?
Yes it does, although it appears the check for this is in the source
code rather than in the .sql file:
#ifndef USE_PROJ
PG_FUNCTION_INFO_V1(transform);
Datum transform(PG_FUNCTION_ARGS)
         elog(ERROR,"PostGIS transform() called, but support not
compiled in.  Modify your makefile to add proj support, remake and
re-install");
         PG_RETURN_NULL();
#endif
Incidentally I've just noticed that you've also committed the changes
about PostGIS requiring PROJ.4 support to SVN trunk. I wouldn't worry
about this, since PROJ.4 and GEOS are compulsory dependencies for 1.4
(i.e. configure won't let you continue until you have installed both of
them).
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
