[postgis-devel] Release notes for 1.3.4
Obe, Regina robe.dnd at cityofboston.gov
Mon Nov 24 20:01:34 PST 2008
+1
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Kevin Neufeld
Sent: Mon 11/24/2008 9:30 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Release notes for 1.3.4
OK... Fire away.
Paul Ramsey wrote:
> OK, it sounds like we are getting down to brass tacks.
> I've put this content into NEWS.
> Kevin, there's a 1.3.4 file already in the downloads directory, from
> an old autorun, that'll have to be moved out of the way.
> Time to release, methinks...
> p.
> On Thu, Nov 20, 2008 at 7:18 AM, Mark Cave-Ayland
> <mark.cave-ayland at siriusit.co.uk> wrote:
>> Obe, Regina wrote:
>>> My only suggestion.
>>> These I don't consider bug fixes and I think should be moved to Features
>>> or we create a new section called Enhancements.  To me bug fixes are
>>> correcting things that don't produce the right outputs rather than
>>> making turtles faster or more understandable.
>>> Enhancements
>>> - Improve PiP code by removing substantial memory leaks and adding
>>> multi-polygon support (Paul Ramsey)
>>> - Improve GiST consistent performance (Paul Ramsey)
>>> - General documentation improvements (Regina Obe, Kevin Neufield)
>>> - GBT#20: Improved algorithm for ST_DWithin (also proposed ST_DFullyWithin
>>> ?) (Paul Ramsey)  (I don't think we ever did the
>>> ST_DFullyWithin)
>> Yeah, I think renaming the first section from Features to Enhancements and
>> including the above in Enhancements would work fine (I'm not too concerned
>> either way). Since Paul is the release manager, I guess we should let him
>> determine the final text and perform the final commit to the 1.3
>> documentation release notes.
>> ATB,
>> Mark.
>> Mark Cave-Ayland
>> Sirius Corporation - The Open Source Experts
>> http://www.siriusit.co.uk
>> T: +44 870 608 0063
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081124/3d032689/attachment.html>
