[postgis-devel] RE: [postgis-users] PostGIS 1.3.4 Released
Obe, Regina
robe.dnd at cityofboston.gov
Mon Nov 24 23:11:05 PST 2008
Just realized we forgot to mention in the new Features that ST_Transform now works with curves. I thought that was the most important fix
that Mark C. did. Well I guess its too late to add that now.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net on behalf of Paul Ramsey
Sent: Tue 11/25/2008 1:30 AM
To: PostGIS Users Discussion; PostGIS Development Discussion
Subject: [postgis-users] PostGIS 1.3.4 Released
After a lengthy development and testing process, it is with some
trepidation that we bring PostGIS 1.3.4 out into a harsh and
unforgiving world.
http://postgis.refractions.net/download/postgis-1.3.4.tar.gz
- New Features
- Add new ST_AsGeoJSON() function to allow conversion of
geometries to GeoJSON format within the database. (Olivier Courtin)
- Add forthcoming PostgreSQL 8.4 support
(Paul Ramsey, Mark Cave-Ayland)
- Improved CSS for PostGIS documentation (Dane Springmeyer)
- Inclusion of new "postgis_comments.sql" file to enable detailed
function comments to be installed for PostGIS functions. This
attaches a description and associated parameter information
to each function so that this information is available directly
within psql/pgAdmin (Regina Obe)
- Enhancements and Bug Fixes
- General documentation improvements (Regina Obe, Kevin Neufield)
- Improve PiP code by removing substantial memory leaks and adding
multi-polygon support (Paul Ramsey)
- Improve GiST consistent performance (Paul Ramsey)
- GBT#20: Improved algorithm for ST_DWithin (Paul Ramsey)
- GBT#21: locate_along_measure: wrong values, invalid data
(Mark Cave-Ayland)
- GBT#23: wrong proj4text in spatial_ref_sys for SRID 31300 and 31370
(Paul Ramsey)
- GBT#43: Heap over-read in compute_geometry_stats() (Landon Fuller)
- GBT#44: ST_Relate(geom,geom,pattern) is case sensitive (Paul Ramsey)
- GBT#45: bug in postgis_restore.pl - not passing options to createdb
(Paul Ramsey)
- GBT#58: bounding box of circular string is incorrect (Mark Leslie)
- GBT#65: ST_AsGML kills the backend when fed a CIRCULAR STRING
(Mark Cave-Ayland)
- GBT#66: ST_Dump kills backend when fed CIRCULAR STRING
(Mark Cave-Ayland)
- GBT#68: ST_Shift_Longitude doesn't work with MULTIPOINT
(Mark Cave-Ayland)
- GBT#69: ST_Translate crashes when fed circular string
(Mark Cave-Ayland)
- GBT#70: ST_NPoints Crashes with Curves (Mark Cave-Ayland)
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081125/f83b9481/attachment.html>
