[postgis-devel] Now that we have moved on - getting regression failure on 1.4
Obe, Regina robe.dnd at cityofboston.gov
Tue Nov 25 05:26:18 PST 2008
I compiled 1.4 on OpenSUSE 10.3 with 3.1.0 Geos SVN and all tests pass
except one. regress_bdpoly.
*** regress_bdpoly_expected	2008-11-25 05:38:32.000000000 -0700
--- /tmp/pgis_reg_10751/test_36_out	2008-11-25 06:23:00.000000000
-0700
*** 1,19 ****
! BuildArea|SRID=2;POLYGON((0 0 10,0 10 8,10 10 6,10 0 4,0 0 2))
! BuildArea|SRID=3;POLYGON((0 0 10,0 10 8,10 10 6,10 0 4,0 0 2),(2 2 5,4
2 4,4 4 3,2 4 2,2 2 1),(5 5 6,7 5 7,7 7 8,5 7 9,5 5 10))
  BuildArea|SRID=3;POLYGON((0 0,0 10,10 10,10 0,0 0),(2 2,4 2,4 4,2 4,2
2),(5 5,7 5,7 7,5 7,5 5))
! BuildArea|SRID=3;MULTIPOLYGON(((0 0 10,0 10 8,10 10 6,10 0 4,0 0 2),(2
2 5,4 2 4,4 4 3,2 4 2,2 2 1),(5 5 6,7 5 7,7 7 8,5 7 9,5 5 10)),((20 0
10,20 10 8,30 10 6,30 0 4,20 0 2),(22 2 5,24 2 4,24 4 3,22 4 2,22 2
1),(25 5 6,27 5 7,27 7 8,25 7 9,25 5 10)))
  BdMPolyFromText|SRID=3;MULTIPOLYGON(((0 0,0 10,10 10,10 0,0 0),(2 2,4
2,4 4,2 4,2 2),(5 5,7 5,7 7,5 7,5 5)),((20 0,20 10,30 10,30 0,20 0),(22
2,24 2,24 4,22 4,22 2),(25 5,27 5,27 7,25 7,25 5)))
  BdPolyFromText|SRID=3;POLYGON((0 0,0 10,10 10,10 0,0 0),(2 2,4 2,4 4,2
  ERROR:  Input is not a MultiLinestring
  ERROR:  Input returns more then a single polygon, try using
BdMPolyFromText instead
2,4 4,2 4,2 2),(5 5,7 5,7 7,5 7,5 5)))
--- 1,19 ----
! ERROR:  geometry contains non-closed rings
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
