[postgis-devel] Compilation problems on OpenSUSE 11
Obe, Regina robe.dnd at cityofboston.gov
Thu Nov 27 09:43:06 PST 2008
More info on my compilation problems.
I thought maybe it was a permissions issue so I deleted all the lw and libl files from my /usr/lib/postgresql directory and then ran
compile/make clean/make /make install again on postgis-1.4.0.
After further inspection, it seems that lwpostgis.so is created and copied fine into /usr/lib/postgresql, but
liblwgeom.so  and the symlinks are not.
Looking at the liblwgeom directory of my source - I see a liblwgeom.a  and  liblwgeom.h but no .so files where as the 1.3.4 had these.
and my /usr/lib/postgresql/ directory only contains one file lwpostgis.so
Is this just a difference between 1.4 and 1.3.4 that everything is now in one .so file.
So I take it my problem is with geos-3.1.0.  It seems Paul needed to make a change to that to bring in the new function.  I had originally pulled from the geos-3.1.0SVN nightly build and compiled with that and when that still didn't fix the problem I thought I then pulled from the SVN repository.  I might have been mistaken there so I'm repeating that part and will see how that goes.
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081127/52a719a6/attachment.html>
