[postgis-devel] Issue 77 in postgis: make check - is thereanywayfor us to delete postgis_reg db when load fails
strk strk at keybit.net
Fri Nov 28 09:36:11 PST 2008
On Fri, Nov 28, 2008 at 01:59:07AM -0500, Obe, Regina wrote:
> Sandro,
> I can see the benefit from debugging I think.  I was thinking not so much dropping on failure but having it check before regress to see if the db exists and then dropping it if it exists rather than just not being able to continue.
Yeah. +1.
--strk;
