[postgis-devel] Issue 33 in postgis: AddGeometryColumns function does not check if SRID is valid
codesite-noreply at google.com codesite-noreply at google.com
Thu Oct 2 18:58:07 PDT 2008
Issue 33: AddGeometryColumns function does not check if SRID is valid
http://code.google.com/p/postgis/issues/detail?id=33
Comment #3 by mrk.leslie:
An escaped quote in the 1.3 branch was causing regression failure when
loading
lwpostgis.sql.
   psql:lwpostgis.sql:2923: ERROR:  syntax error at or
near "AddGeometryColumns"
   LINE 91:    RAISE EXCEPTION 'AddGeometryColumns() - invalid SRID';
The same issue was not found in trunk.
Fix committed at r3057.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
