[postgis-devel] Prepared Geometry API
Obe, Regina robe.dnd at cityofboston.gov
Mon Oct 6 11:52:44 PDT 2008
What about using the PG_GETARG_POINTER does that return the same for all
constants too?
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Monday, October 06, 2008 2:48 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Prepared Geometry API
The answer seems to be that, for data in tables, this works OK, but
for literals, it's possible for different literals to get the same
datum number:
select a.val as a, b.val as b, st_contains(a.val, b.val, 0) from
(select 'POINT(0 0)' as val union select 'POINT(1 1)' as val) a,
(select 'POINT(0 0)' as val union select 'POINT(1 1)' as val) b;
This ends up returning the same datum number for 0,0 as well as 1,1. :(
P.
On Mon, Oct 6, 2008 at 11:23 AM, Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> Why can't I just this this:
> key1 = PG_GETARG_DATUM(0)
> key2 = PG_GETARG_DATUM(1)
> the datums are just uint, and they don't get turned into pointers
> until further down the line... I just tried changing my contains code
> to do this, and I got the same answer in the same amount of time.  Are
> the datum numbers reliable "object identifiers"?
> P.
> On Mon, Oct 6, 2008 at 10:53 AM, David Fuhry <dfuhry at acm.org> wrote:
>> ctid will work for that, but I believe it would have to be passed
into the
>> function as a separate argument from the geometry, so API ugliness
remains.
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
