[postgis-devel] Dropped DM (Time) dimension with intersections
Obe, Regina robe.dnd at cityofboston.gov
Tue Oct 7 09:44:26 PDT 2008
I'm not sure how low hanging the fruit :), but first off would be being able to do intersections and indexable ST_DWithin with 3D polygons and linestrings and so forth. For example when I place a cable up on a roof I need to know if I'm hitting another piece of equipment.
Higher fruit - being able to support volumetric geometries.  Right now we support 2d-3D polygons and lines and you can form wireframes with those, but no true volumetric stuff.  But then what do I know, I'm just parroting things I've heard in whispers and those whispers are getting louder is all :)
There is still the issue of being able to display 3-D geometries without spending a fortune on proprietary stuff which is not a PostGIS issue, but has to gain in momentum to make PostGIS 3D more powerful (e.g. uDig for 3D or OpenJump for 3D or OpenLayers for 3D?)
Thanks,
Regina
From: postgis-devel-bounces at postgis.refractions.net on behalf of Paul Ramsey
Sent: Tue 10/7/2008 12:30 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Dropped DM (Time) dimension with intersections
Perhaps elabourate on what better 3D support would be? There's the
surface object hanging around. There's the issue of maintaining higher
dimensional coordinates through lower dimensional transforms (which
you saw the result of a few days ago). There's elabourating the
complete set of 3D objects and relationships (gulp).
It's not clear to me what is the "low hanging fruit" that will make 3D
users happiest in the shortest time.
P.
On Tue, Oct 7, 2008 at 8:54 AM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> Margie,
> Unfortunately I think the answer is no.  Most of the work going on in 1.4 is
> to improve speed of existing functionality and reorganize the source to make
> it more maintainable.
> Someone please correct me if I am wrong.
> I for one would be very elated if we had better 3D support since CityGML and
> similar initiatives are becoming more of a hot topic around here.
> Thanks,
> Regina
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
> Huntington, Margaret (US SSA)
> Sent: Tuesday, October 07, 2008 11:47 AM
> To: postgis-devel at postgis.refractions.net
> Subject: [postgis-devel] Dropped DM (Time) dimension with intersections
> Hello,
>     Currently I'm using PostGIS 1.3.3.  From past discussions and from
> testing, both the st_intersection st_extend methods return 2D results with
> 4D input geometries.  As a temporary work-around, I had hoped
> st_intersection might work with 3DM geometries.  (Plan was to interpolate
> the altitude value within the function call if PostGIS could calculate the
> time dimension).   I found time components are also dropped by
> st_intersection with 3DM geometries.  I abandoned usage of 4D bounding boxes
> since these too effectively degrade 4D geometries down to 2D geometries
> (altitude and time are zeroed out).
>     polyGeometry geometry;
>     bbGeometry geometry;
>     intersectionGeometry geometry;
>     coorddims smallint;
>            -- both polygon and linestring have an expected zmflag value of 1
>            polyGeometry := 'SRID=4326;POLYGONM((0 0 0, 0 10 4, 10 10 4, 10 0
> 0, 0 0 0))'::geometry;
>            bbGeometry := 'SRID=4326;LINESTRINGM(0 0 1.5, 10 10
> 2)'::geometry;
>            intersectionGeometry := st_intersection(polyGeometry,
> bbGeometry);
>            -- st_intersection method drops the time dimension; zmflag value
> of 0
>            coorddims := st_zmflag(intersectionGeometry);
> If I were to download the subversion snapshot, the current 1.4 version,
> might st_intersection work with either 3DM or 4D geometries?  Are bounding
> boxed or st_extend improved for either 3DM or 4D geometries?  I had
> incorporated polygons only as a possible work-around to the bounding box and
> st_extend 2D limitations.
> Margie
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure pursuant to
> Massachusetts law. It is intended solely for the addressee. If you received
> this in error, please contact the sender and delete the material from any
> computer.
> Help make the earth a greener place. If at all possible resist printing this
> email and join us in saving paper.
> postgis-devel mailing list
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081007/798f384a/attachment.html>
