[postgis-devel] Prepared Geometry API
Obe, Regina
robe.dnd at cityofboston.gov
Wed Oct 8 10:43:26 PDT 2008
Hmm okay. Don't see why renumbering is a bad thing unless it uses a number right from the previous materialize that you still have in your cache. I'm still trying to visualize a query that would have multiple materializations where the materialized numbers would actually be reused within the query. I would expect other use cases aside from PostGIS use to crumble.
I guess better to close the chapter safely than risk something. Though would be interesting to reopen this chapter later.
So are you guessing you will suffer 5-10% speed loss with using memcmp over using datum assuming datum is safe?
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Paul Ramsey
Sent: Wed 10/8/2008 11:45 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Prepared Geometry API
Mark figures Materialize will re-number everything, so there's no
guarantees. Given the memcmp speed results, and the desire on this
list to retain a uniform API, I'm going go finish moving everything to
memcmp so we can close this chapter.
P.
On Wed, Oct 8, 2008 at 5:28 AM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> Paul,
> Would seem so. Though I'd be more convinced if I saw a true
> non-constant subquery.
> Anyrate from your other threads, I take it you have put this out to
> pasture and have decided on a memcpy based solution?
> Thanks,
> Regina
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
> Ramsey
> Sent: Tuesday, October 07, 2008 4:45 PM
> I see the datum numbers are also consistently tracking changes when I
> add those in:
> POSTGIS_DEBUGF(1, "arg 1 pointer(%x) datum(%d) arg 2 pointer(%x)
> datum(%d)", PG_GETARG_POINTER(0), PG_GETARG_DATUM(0),
> PG_GETARG_POINTER(1), PG_GETARG_DATUM(1));
> Does this mean that using the datum numbers is a possible sol'n?
> postgis2=#
> postgis2=# SELECT a.val as a,
> b.val as b, _st_containsprepared(a.val, b.val,0)postgis2-#
> FROMpostgis2-# (SELECT 'POINT(0 0)'::geometry as val UNION SELECT
> 'POINT(1 1)'::geometry as val) a,
> postgis2-# (SELECT 'POINT(3 4)'::geometry as val UNION SELECT
> 'POINT(1 1)'::geometry as val) b;
> NOTICE: [lwgeom_geos_c.c:containsPrepared:3931] arg 1 pointer(731d7c)
> datum(7544188) arg 2 pointer(732e9c) datum(7548572)
> NOTICE: [lwgeom_geos_c.c:containsPrepared:3934] arg 1 ewkt: POINT(0 0)
> NOTICE: [lwgeom_geos_c.c:containsPrepared:3936] arg 2 ewkt: POINT(1 1)
> datum(7544188) arg 2 pointer(732e54) datum(7548500)
> NOTICE: [lwgeom_geos_c.c:containsPrepared:3936] arg 2 ewkt: POINT(3 4)
> NOTICE: [lwgeom_geos_c.c:containsPrepared:3931] arg 1 pointer(73302c)
> datum(7548972) arg 2 pointer(8586f4) datum(8750836)
> NOTICE: [lwgeom_geos_c.c:containsPrepared:3934] arg 1 ewkt: POINT(1 1)
> datum(7548972) arg 2 pointer(732f4c) datum(7548748)
> a | b
> 010100000000000000000000000000000000000000 |
> 0101000000000000000000F03F000000000000F03F | f
> 010100000000000000000008400000000000001040 | f
> 0101000000000000000000F03F000000000000F03F | t
> (4 rows)
> On Tue, Oct 7, 2008 at 1:29 PM, Mark Cave-Ayland
> <mark.cave-ayland at siriusit.co.uk> wrote:
>> Obe, Regina wrote:
>>> Paul,
>>> Something is bugging me about your choice of example. Not that it is
>>> important, but your a and b tables are the same constant so I would
> expect a
>>> planner to realize that and make a and b point to the same thing.
> I'm not
>>> sure how that muddies your analysis. Also your constant gets cast as
> a
>>> geometry only when it gets into ST_Contains and you are doing a UNION
>>> instead of a UNION ALL.
>>> What does the revised query give you
>>> SELECT a.val as a, b.val as b, st_contains(a.val, b.val,0)
>>> FROM
>>> (SELECT 'POINT(0 0)'::geometry as val UNION ALL SELECT 'POINT(1
>>> (SELECT 'POINT(3 4)'::geometry as val UNION ALL SELECT 'POINT(1
>>> Thanks,
>>> Regina
>> The UNION ALL seems to work for me. Using the attached patch against
> SVN
>> trunk and EXPLAIN, it is possible to see that it is the Materialize
> node
>> which causes the Datum pointers to change. Also it's worth noting that
>> st_contains() invokes the bounding box filter first which is a little
>> confusing when looking at this - things were a lot clearer to me using
> the
>> following queries:
>> SELECT a.val as a, b.val as b, _st_containsprepared(a.val, b.val,0)
>> FROM
>> (SELECT 'POINT(0 0)'::geometry as val UNION SELECT 'POINT(1
> 1)'::geometry
>> as val) a,
>> (SELECT 'POINT(3 4)'::geometry as val UNION SELECT 'POINT(1
> 1)'::geometry
>> as val) b;
>> FROM
>> ATB,
>> Mark.
>> Mark Cave-Ayland
>> Sirius Corporation - The Open Source Experts
>> http://www.siriusit.co.uk
>> T: +44 870 608 0063
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081008/c73b48fa/attachment.html>
