[postgis-devel] Prepared Geometry API
Obe, Regina robe.dnd at cityofboston.gov
Wed Oct 8 11:01:27 PDT 2008
Ah okay if its 1% then no biggie.  Thought it was worse than that
if as someone said real use case doesn't use L2Cache and Marks' comment about hand optimizing assembly (do all platforms have hand-optimized glibc? I don't even know what that is).
I probably missed something
in my faulty C garble to Regina simpleton english.  As you were then.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Paul Ramsey
Sent: Wed 10/8/2008 1:56 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Prepared Geometry API
I'm guessing I'll lose 1%. So I'm not crying over it too much. Using
Datum would be nice, but I need a Wizard to tell me it's safe, I'm not
capable of proving it to myself to my own satisfaction.
P.
On Wed, Oct 8, 2008 at 10:43 AM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> So are you guessing you will suffer 5-10% speed loss with using memcmp over
> using datum assuming datum is safe?
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081008/6bc91570/attachment.html>
