[postgis-devel] Dropped DM (Time) dimension with intersections
Martin Davis mbdavis at refractions.net
Wed Oct 8 17:20:08 PDT 2008
Not me... the 3D elves must have snuck this one into GEOS   8^)
Obe, Regina wrote:
> Chris,
> That was a bit of a trick question :)  It tells me ST_ConvexHull is
> not ignoring the z-index.
>  I was puzzled that convex hull supports 3-d is all since it is a GEOS
> function and I was under the impression no GEOS functions support
> 3-d.  But looking at the code, looks like it is one of those ones that
> somebody snuck in 3d support though I haven't compared with JTS code
> base to be sure.  Maybe Martin can comment.
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net on behalf of Chris
> Hodgson
> Sent: Tue 10/7/2008 2:10 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] Dropped DM (Time) dimension with
> intersections
> I think the answer is, nobody really knows, but it seemed to make as
> much sense as possible given the operation being requested. If it
> doesn't work for your use case then feel free to make a solid argument
> for why we should give a different result and provide a robust method to
> calculate it :-)
> Chris
> Obe, Regina wrote:
> > Which begs the question - what exactly does this tell me?
> > SELECT
> > ST_AsEWKT(ST_ConvexHull(ST_Collect(ST_GeomFromEWKT('LINESTRING(1 2 3,3
> > 4 5, 3 6 7)'), ST_MakePoint(0, 2, 0))));
> > Result
> > "POLYGON((0 2 0,3 6 7,3 4 5,1 2 3,0 2 0))"
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> *The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended solely for the
> addressee. If you received this in error, please contact the sender
> and delete the material from any computer. *
> * Help make the earth a greener place. If at all possible resist
> printing this email and join us in saving paper. *
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
