[postgis-devel] 1.4 SVN Compile problems
Paul Ramsey
pramsey at cleverelephant.ca
Fri Oct 10 09:33:12 PDT 2008
Does this buildbot have an error log anywhere? It's pretty hopeless to
debug, it's not like I'm committing things that are broken for *me*,
so I need to see what's broken for *it*. BTW, it'll need to re-run
./configure to pick-up the file re-naming.
P.
On Fri, Oct 10, 2008 at 8:16 AM, Kevin Neufeld <kneufeld at refractions.net> wrote:
> It could simply be that trunk is currently in an unstable build state. (The
> autobuild is currently in a broken state as of three commits ago - revision
> 3086). It errors out compiling lwgeom_geos.o
> http://postgis.refractions.net:8082/
> Cheers,
> Kevin
> Mark Cave-Ayland wrote:
>> Obe, Regina wrote:
>>> This is probably my ineptness at compiling, but I thought I would try to
>>> experiment with 1.4 and got errors when its trying to compile the
>>> loader. Errors below. If I go into lwgeom etc. other directories and
>>> compile those separately, those seem to compile okay so seems to be just
>>> the loader that is giving me problems. What changed between 1.3.4SVN and
>>> 1.4SVN for the loader. I didn't have
>>> problems compiling 1.3.4SVN.
>>> The others just seem to be warnings (which I don't remember getting
>>> before) except for this part
>>> lkrb5 -lz -lreadline -lcrypt -ldl -lm -o shp2pgsql
>>> /usr/lib/gcc/i586-suse-linux/4.2.1/../../../../i586-suse-linux/bin/ld:
>>> cannot find -lkrb5
>>> collect2: ld returned 1 exit status
>>> This is on OpenSUSE 10.3 against a PostgreSQL 8.2.6 install
>>> Thanks,
>>> Regina
>> Hmmmm looks as if the extra library dependencies are being added by PGXS
>> for the PROGRAM target - I have no idea why it feels the need to do this
>> though? The quick fix is to add the krb5 development headers which should be
>> in a package named something similar to krb5-devel or libkrb5-dev.
>> ATB,
>> Mark.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
