[postgis-devel] 1.3.4
Paul Ramsey pramsey at cleverelephant.ca
Fri Oct 10 12:09:40 PDT 2008
Correct. Absent a GEOS 3.1, everything remains "as is".
P.
On Fri, Oct 10, 2008 at 12:02 PM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> But if you are using geos 3.0.0 it is not going to try and use prepared
> geometry at all correct?
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net on behalf of Paul Ramsey
> Sent: Fri 10/10/2008 2:22 PM
> To: PostGIS Development Discussion
> Subject: [postgis-devel] 1.3.4
> OK, I've made the prepared geometry work underneath the existing API,
> so the key-based API has been removed.
> Make sure you have the latest GEOS before trying these things, as
> anything prior to the current revision still has leaks.
> Paul
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> ________________________________
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure pursuant to
> Massachusetts law. It is intended solely for the addressee. If you received
> this in error, please contact the sender and delete the material from any
> computer.
> Help make the earth a greener place. If at all possible resist printing this
> email and join us in saving paper.
