[postgis-devel] 1.3.4?
Obe, Regina robe.dnd at cityofboston.gov
Fri Oct 10 12:15:26 PDT 2008
Paul,
Works on my 1.3.3 install.
I even tried this with srids and casting to null to geometry and also dumping to a temp table.
SELECT  * INTO tmp FROM (SELECT NULL::geometry UNION ALL
SELECT ST_GeometryFromText('POLYGON((0 0, 2 0, 2
2, 0 2, 0 0))',4326)
UNION ALL
SELECT NULL::geometry) As foo(g) cross join generate_series(1,10) n
SELECT ST_Union(g) from tmp
group by n;
What was Charlie whining about then?  Maybe he can provide an example of where it fails.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Paul Ramsey
Sent: Fri 10/10/2008 2:55 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] 1.3.4?
Just a sec. Do our aggregates not already *do* the right thing WRT nulls?
ebc=# select st_astext(st_union(g)) from ( values ('POINT(0 0)'),
(NULL), ('POINT(1 1)') ) as v(g);
       astext
 MULTIPOINT(0 0,1 1)
(1 row)
ebc=# select astext(st_union(g)) from ( values ('POLYGON((0 0, 2 0, 2
2, 0 2, 0 0))'), (NULL), ('POLYGON((1 1, 1 3, 3 3, 3 1, 1 1))') ) as
v(g);
                     astext
 POLYGON((1 2,1 3,3 3,3 1,2 1,2 0,0 0,0 2,1 2))
(1 row)
On Mon, Oct 6, 2008 at 3:52 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Paul Ramsey wrote:
>> OK, Mark's tickets are closed.
>> That just leaves the handling of NULL and = and ST_Equals as issues.
>> I'm inclined to deal with *none* of these, since they all change
>> behavior, which is not good for a point release.  However, if people
>> are convinced that certain of these behaviors are UNAMBIGUOUSLY WRONG,
>> then we could change them.
>> I can see changing the aggregates to be more NULL savvy as one of those
>> cases.
>> P.
> +1. For 1.3 let's look at mimicking the standard aggregate behaviour with
> respect to NULLs and leave the =/ST_Equals() debate for a later release.
> ATB,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081010/1dde30df/attachment.html>
