[postgis-devel] Issue 44 in postgis: ST_Relate(geom, geom, pattern) is case sensitive
codesite-noreply at google.com codesite-noreply at google.com
Fri Oct 10 16:13:32 PDT 2008
Issue 44: ST_Relate(geom,geom,pattern) is case sensitive
http://code.google.com/p/postgis/issues/detail?id=44
Comment #1 by pwramsey3:
Fixed in trunk and 1.3
Issue attribute updates:
	Status: Fixed
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
