[postgis-devel] 1.3.4SVN Testers Needed
Havard Tveite havard.tveite at umb.no
Mon Oct 13 14:25:13 PDT 2008
Errors at the same place here - Solaris 2.7, gcc 3.3.2:
  g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers -I../../source/headers/geos
-I../../source/headers -g -O2 -DGEOS_INLINE -Wall -ansi -pedantic -Wno-long-long
  -MT CLocalizer.lo -MD -MP -MF .deps/CLocalizer.Tpo -c CLocalizer.cpp  -fPIC -DP
IC -o .libs/CLocalizer.o
CLocalizer.cpp:1:32: geos/io/CLocalizer.h: No such file or directory
CLocalizer.cpp:11: error: syntax error before `::' token
CLocalizer.cpp:18: error: ISO C++ forbids declaration of `setlocale' with no
    type
CLocalizer.cpp:18: error: declaration of `setlocale' not in a namespace
    surrounding `std'
CLocalizer.cpp:18: error: `int std::setlocale' redeclared as different kind of
    symbol
/usr/include/locale.h:102: error: previous declaration of `char* setlocale(int,
    const char*)'
CLocalizer.cpp:18: error: initializer list being treated as compound expression
CLocalizer.cpp:18: error: invalid conversion from `const char*' to `int'
CLocalizer.cpp:21: error: syntax error before `::' token
make[2]: *** [CLocalizer.lo] Error 1
make[2]: Leaving directory `/data3/usr/local/src/geos/geos-3.1.0/source/io'
Håvard Tveite
Dane Springmeyer wrote:
> Paul,
> Just tried building GEOS from the provided svn download on Mac 10.5.5
> and I get this error during make:
>         then mv -f ".deps/Unload.Tpo" ".deps/Unload.Plo"; else rm -f ".deps/
> Unload.Tpo"; exit 1; fi
> headers/geos -I../../source/headers -g -O2 -DGEOS_INLINE -Wall -ansi -
> pedantic -Wno-long-long -MT Unload.lo -MD -MP -MF .deps/Unload.Tpo -c
> Unload.cpp  -fno-common -DPIC -o .libs/Unload.o
> Unload.cpp -o Unload.o >/dev/null 2>&1
> if /bin/sh ../../libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H -
> I. -I. -I../../source/headers -I../../source/headers/geos -I../../
> long-long -MT CLocalizer.lo -MD -MP -MF ".deps/CLocalizer.Tpo" -c -o
> CLocalizer.lo CLocalizer.cpp; \
>         then mv -f ".deps/CLocalizer.Tpo" ".deps/CLocalizer.Plo"; else rm -f
> ".deps/CLocalizer.Tpo"; exit 1; fi
> pedantic -Wno-long-long -MT CLocalizer.lo -MD -MP -MF .deps/
> CLocalizer.Tpo -c CLocalizer.cpp  -fno-common -DPIC -o .libs/
> CLocalizer.o
> CLocalizer.cpp:1:32: error: geos/io/CLocalizer.h: No such file or
> directory
> CLocalizer.cpp:11: error: 'CLocalizer' has not been declared
> CLocalizer.cpp:11: error: ISO C++ forbids declaration of 'CLocalizer'
> with no type
> CLocalizer.cpp: In function 'int geos::io::CLocalizer()':
> CLocalizer.cpp:16: error: 'saved_locale' was not declared in this scope
> CLocalizer.cpp: At global scope:
> CLocalizer.cpp:21: error: expected constructor, destructor, or type
> conversion before '::' token
> CLocalizer.cpp:19: warning: control reaches end of non-void function
> make[1]: *** [all-recursive] Error 1
> make: *** [all-recursive] Error 1
> I see it must be related to http://trac.osgeo.org/geos/ticket/201
> Let me know if I'm missing something.
> Dane
> On Oct 13, 2008, at 11:57 AM, Paul Ramsey wrote:
>> 1.3.4 is very close to release, but we can release it faster, with
>> less intestinal distress, if we get some solid pre-release testing
>> from folks. You can download the current SVN version directly from the
>> downloads page, no SVN client required:
>> http://postgis.refractions.net/download/postgis-1.3.4SVN.tar.gz
>> If you want to also try the latest preparedgeometry enhancements,
>> you'll need to upgrade your GEOS version to the SVN trunk before
>> compiling and installing1.3.4SVN,
>> http://download.osgeo.org/geos/geos-svn.tar.bz2
>> Even if you don't, you should see some performance increases in 1.3.4,
>> particularly in point-and-polygon predicate tests, and large joins
>> using point-ant-polygon predicates.
>> Let us know how it goes. We are particularly  interested in any
>> compilation difficulties or regression failures on less common unix
>> variants (Solaris on Sparc, AIX on Power, etc)
>> Paul
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Håvard Tveite
Department of Mathematical Sciences and Technology
Norwegian University of Life Sciences
